96 ranger 302 swap | Ford Explorer Forums
96 ranger 302 swap
geninject
maryland
96 ranger
I need any and all help with my ranger V8 conversion.I have a 96 ford ranger im trying to put a 97 Explorer
302 in it.Im running into clearace issues putting the engine in.I bought different motor mounts for a mustang cov.
I also have the double sump oil pan off a mustang.Im using the mountaineer tranny with transfer case.
I origanally wanted to use the transfer case that I took off but it uses 5 bolts to bolt to the tranny.
so I had to use the mountaineer transfer case that is four wheel drive all the time :(.Im still not having sucsess
matching the engine with the motor mounts I bought.Any feedback is appreciated
thanks
hopefully i wil;l be able to contact riverrat if i see him on
...You can click on his name nd send him a pm..;)
geninject,
I got your message.
I used the L&L mounts, AA transfer case adapter and mustang double sump pan. My truck also has a body lift which helped out greatly with engine and 4R70W clearance. I only have about 1/2 inch between the oil pan and crossmember.
What are your problems?
