bobber1
- November 29, 2006
- 1996 Ford Ranger
Hi all:
Have a 1996 Ford Ranger 2.3 4 cyl 5 speed manual. Experienced a situation where the temp barely moves to the normal and is fluctuating between cold and normal. Seemed like classic case of thermostat stuck open so changed that. The problem still exists. I put the obd II on it to monitor the water/coolant temp. On the obd the temp fluctuates between 160 and 185 or 190ish. This is even after running/driving the truck for minimum 30 minutes with the hvac control in the off position. The heater blows lightly warm at best but that seems to be due to the lack of water temperature. I have seen some posts pointing to the water pump as the culprit, but would that account for the low temps I'm seeing on the obd II?
Thanks in advance for the help!
Bobber
Bobber
