monty98
- October 1, 2018
- 1998 Mountaineer 5.0 AWD
On trip 2 hrs from home check gauge light came on & temp gauge red lined! Pulled over. Checked to see if hose or coolant issue. Coolant level as when checked night before. Deciding which vehicle to take on the trip 98 or 97 the 98 wasn't producing heat (need replace the control that goes on the box behind glove compartment. Heat was hot & ran consistent on the 97..so that became selected vehicle. Little apprehension as hadn't driven it except home after mechanic changed passenger exhaust manifold, head gasket, new fuel injectors & plugs. It was running great til the overheat issue. What I had noticed morning was a slight very quiet whistle near front engine only hear with hood up...couldn't see any issues. Also noticed gurgling sound seemed like center possibly firewall area. The gurgling not always evident but noticed on load or acceleration it got louder but only occasionally. Thought it might just be air in the system after all hoses off etc for the work done. But then the redline without any notice. Wasn't running heat at time so after cooled down thought maybe drive with heat on which would help if thermostat issue. But no heat. Hoses hot tho. Limped along stopping time to time til could get off freeway. It would cool when basically coasting downhill but as soon as had to accelerate to go uphill the gauge would start climbing. I was in very hilly area so no options & had to get off freeway! Went back next day & hauled it home on trailer.
Love this type issue just when going into cold weather & no place inside to work on it. Had done a flush about year before & had a small leak & some coolant in exhaust. Used K-seal & it helped some before all the mechanical work described above due to #3&4 serious misfires even after new plugs, wires.
Does what I describe about the overheat/no heat issue sound like the pump gone bad? Its got about 136k on it & read often around 150 might have issues (wish had known when everything else was apart). One mechanic without seeing it, based on description says pump (2 mechanics work on this vehicle regularly). Anything else I should check...any possibility something else? Oh the tstat was changed year ago but with no heat & overheating engine doesn't seem likely culprit. But whatever it was went fatal without much notice.
Sorry so long but thought might be helpful to know what has been done so far. I've searched forum but nothing quite like this shows up. Thanks in advance for any input.
