- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Hi Hacra,
All I am saying is that you should try is removing the 2 old ABS Sensors, clean them off and put them back on. At this stage/point, I am not saying you should go out and buy new sensors. With regards to your old ABS sensors - the "faces" of these sensors get contaminated with a coating of fine ground metal dust. The metal dust contamination will cause the ABS system to not work correctly. That's why it's worth a try to remove and clean them, as more than likely they have never been cleaned.
REAR ABS SENSOR: The rear ABS sensor is 1 BIG sensor located on top/passenger side of the rear differential. 1 bolt holds it down. After you remove the 1 bolt, you remove the ABS Sensor by twisting it right/left while at the same time pulling it upwards.
The front ABS sensors on 2WD's are external and need cleaning occasionally. The front 4WD/AWD sensors are internal, bathed in grease, they never need removal.
