wombat
- February 17, 2009
- Hodgenville, KY
- 97 EB 4D
This is my first post, I have spent a couple hours bounmcing around and searching before I joined and posted. I fiancee just bought a used 97 Explorer AWD. (I'm a GM guy) She was driving down the road the other day on the interstate and he truck quit pulling, like it had been put in neutral. When placed in park the park pin clicks until the tranny speed slows down (like the T-case is in neutral). When we got it home (under it's own power with no OD) I imediatly pulled the T-case motor to check and make sure it was still functioning.. Everything seemed good. I put it back on and drove around the field and it still acted the same way. Drives like it is in 4-low. But when I turn the selector switch to 4 low it drives alot smoother. So I took it to the local tranny shop, I figured the OD solenoid went bad, but when he hooked up his scanner all it said was that thein dash switch was bad.. Also while driving it on the road (35 MPH 3,000 RPM) the OD light flashes... Any ideas? is this a usual proplem? The truck only has 140K on it. Please help.
(she saw me surfing around the sight and now want a TT and shackle lift with 31 or 32's... Great)
Josh
Josh
