97 Explorer V6 2WD cranks won't start | Ford Explorer Forums
Seaeric
Ft Lauderdale, Fl.
97 XLT
Its been sitting for 3 months. Ran fine last time I drove it. Fuel gauge says 3/4 full, she spins over fine but doesn't give any indication that it will start. I'm not mechanical at all, but before I call the hook is there anything I should check?
Can you hear the fuel pump priming when you turn the key to the on position without cranking?
I'm going to check that next. If not, is there a corresponding fuse that could be blown?
I don't hear the fuel pump at all when the key is on. I see in the owner's manual that there is a fuel pump switch. I'm not clear on where that may be located.
It needed a fuel pump. I'm back up and running.
