SpyrDragon
- December 5, 2019
- Owensboro, Ky
- 1996 Explorer XLT
So when i bought my 97 5 speed, the guy told me that the transfer case worked. Well, I went and checked and it does not appear to be working. He already had the shift motor replaced as I could tell when I was under the truck trying to fix the speedometer. Here's what's happening:
The other thing i noticed is that every single time I turn the truck on, even if I don't start it, I can hear the Transfer Case relay (the little gray box behind the radio next to the GEM) clicking several times. I'm not sure if the relay could be causing the problem; want to see what else I can find out before spending the money to replace it. As far as diagnosis, here is what i managed to find out:
I do plan on looking at the wiring diagrams for the shift module and make sure that's all working right. I was hoping to see if anyone else had a similar issue. I was mostly curious about the shift relay clicking everytime the key is turned on and if it might be related at all. I searched everywhere but couldn't find anything. Hoping someone may be able to help me out here. Oh and yes, I did check all of my fuses and every one of them is good so that's definatly not an issue.
Thanks.
I start the truck and both the 4WD and 4WD Low lights come on during the bulb check then go off as they should. I turn the switch to 4HI and the 4WD light comes on, but i dont hear any clicking or anything indicating that it shifts, not even hearing the trasfer case shifting. When I put it in Neutral with the clutch down and the brake pressed, I switch it to 4LOW but nothing happens at all, the 4WD Low light doesnt even come on.
I had a scan tool hooked up looking at the 4X4 datastream coming from the GEM. I can confirm that the switch is good as the GEM is getting output from the switch. I could see the switch postion reporting correctly. When I switched to 4HI, the GEM reported that the transfer case was switching to 4HI, but the readouts showing the transfer case clutch positions did not change as if the transfer case wasn't attempting to shift. When I tried 4LOW, the tranfer case clutch postions still didn't change, but the GEM was reporting that it was still in 4HI and did not switch to 4LOW even though the switch requested it. I also confirmed that the front and rear speed sensors are working; put it in gear and got a speed readout on both.
Thanks.
