97xlimited
- October 16, 2013
- Denver Pa
- 97 Explorer Limited
(I apologize in advance for the length of the post.)
I've been working on cars for nearly 20 years now and this truck has me chasing my tail. I've read post on here for years and your community is great about answering question so I decided to post.
I have a 97 limited 5.0l with a 4406e swapped transfer case. I'm new to posting so pictures are not as easy, so bear with me.
First, I bought the truck already swapped and wired. It is not a manual shift it is electric. I have a wobble/vibration at 15-20MPH on deceleration and acceleration but not at a cruise. It goes away and a vibration comes back a 30-35MPH and stays there until 50-55MPH but varies in intensity; again not at a cruise. Seems, sounds and feels like a drive-line vibration. Whats been done:
1. New/Used front drive shaft shortened and balanced
(The old one was done incorrectly and could have damaged the tcase)
2. New ujoints front and rear shafts
3. Replaced front differential (old one puking out the vent and the gear backlash was slightly out) Inspected the rear and change fluids.
4. Went through EVERYTHING else including measuring the tires diameter with a tape measure. Ran it on a lift to check for vibration location and found the tcase to be shaking slightly. Trans mount OK.
So I'm thinking at this point the tcase must be bad due to the old front shaft. If I remove the front shaft the vibration is gone. Took the shaft back to the drive-line shop yesterday to have it rechecked and its not a issue. Changed the tcase fluid, it was OK if not a little dark. Not burned just dirty. It could be angles but have not heard that that was much of an issue on the swaps.
I have read on here that the GEM can sometimes cause a issue so I went to the salvage yard and got a replacement just to see. That GEM made the vibration way worse even though the part numbers matched. Now there is no telling when that GEM was updated last. They were both for a 97 4.0l a4wd model truck. I also took time to check the wiring on mountys and other Xs as well as other v8 models. When I came home I found another issue.
My X has two wiring harnesses for the 4wd mode switch. One was spliced in and wired like the others, the other seems original but does not match any color set that I saw at the yard (for 96,97 or 98 model years). It also is not wired the same as ALL of the other Xs, mountys, or V8 models. The expeditions are even different. It had a 4wd mode style switch connected to it and was hid behind the panel, but it is only a two position switch. One position is off and the other is on but with variable resistance. The spliced in switch is in the normal position (on the bezel with three positions) and the 4wd does work. I have no idea what the two position switch does. I cant even find any ford in those years that used a two position on/off switch in the 4wd system(f150 maybe, idk) The brown wire is intact but had been splice back together. I though maybe they wired it for 2wd but the two pole switch has no effect on the coil.
Before I condemn the tcase completely, I would like to make sure the wiring is not causing a problem. The two pole switch is connected with power for light (Rd/blk), then the gem wire (Bl/Wht not (Wht/bl) (which does not go to the gem), the next is a ground (Blk/Wht) and the last is a ground (Blk). (Going left to right on the connector installed position). The splice in connector/switch is wired/colored correctly. Switching switches around doesn't seem to work.
Whew! So if anyone has any ideas or info I would love to hear it. I don't know what kind of monkey has been in there messing around, or even whats going on with the wiring and the vibration.:scratch:
Thanks
Thanks
