97 XLT Transfer Case | Ford Explorer Forums
Ronjm
Sydney NEW SOUTH WALES
Explorer XLT 1997 4L SOHC
Hi Guys is there anybody in Australia that knows where I can get a used transfer case for a 1997 XLT 4.0L V6 SOHC. They are really hard to find. I am in NSW 2327.
Thanks
Yes we do have more Rangers so a 97 Ranger t-case should fit?
Your 97 Explorer came with the 4405 case. Mid '97, Ford switched styles of front outputs, and eliminated the mechanical VSS.
For an exact replacement You can look at your t-case tag / stickers, to see if it is a 4405-CA, or 4405-GA. (or run the VIN)
The older IFS (TTB) Rangers and Explorers used a 1354 case, that will also bolt up. The Manual is the preferred case when using these on the '95-'01 Explorers. Straight bolt in swap, no electronics, and more reliable than any case from '91-'01.
The Rangers do not match year to year exactly in generations with the Explorer, and parts shared. I "Think" Rangers are IFS (SLA) from '97+, and are the same from '97-'11. At some point Ford changed out the 4405 in them, and went to a hybrid 1354 in later models, sometime after '01.
You can learn more details in the Ranger section, & the Driveline section.
