98XLT4
- June 21, 2007
- 98 XLT
I've got a '98 XLT with the 4.0 SOHC (2WD) with a strange idle problem. When the truck is cold, the idle is fine at around 700 or so RPM. When the truck warms up to operating temps, the the idle slowly increases as the temp increases - up to a max of about 1000 RPM. After the idle increases, the transmission shifting becomes erratic and seems to "stick" in gear. For instance, at 50 MPH in 5th gear if I take my foot off the gas, the RPM's don't immediately drop but tend to stay up as if I still had my foot lightly on the gas cruising. Any thoughts as to what's causing this problem? I've replaced the IAC already.
