koda2000
- September 2, 2011
- x
Oddly a compressor with clutch is not that much more than the replacement clutch assembly, but it's a lot more labor to replace the compressor. If my compressor is still working fine then I'd just change the clutch assembly as pictured above. It's quite easy to DIY. There's a lot of stress on the clutch bearing and the clutch itself wears down over time. The OE clutch tends to loose it's rubber silencers and rattle (the reason I replaced my first one) and the bearing eventually disintegrates (the reason I changed my second one).
