will7559
- March 2, 2006
- KY
- '98 XLT
This is my first post - yep, I got myself in trouble and need some advice. First, I must say that I have gotten a lot of great advice from this site and it's saved me some $ and I've had fun working on this vehicle.
Anyway, the 4WD 'locked up', dash lights (4H and 4L) blink sometimes. I suspected the shift motor. Tapped it to see if it was maybe stuck. Removed it and saw that it did not move at all when changing the dash dial to different positions. So, it seems that maybe it is the shift motor...
So, here's where I got myself into trouble - I tried to manually (with vise grips) move the high-low collar rod on the transfer case manually from H to N to see if I could disengage the 4WD. I think the rod is now disengaged from whatever it is that it engages inside since I can now turn it freely by hand.
Pretty bad move, huh?
Now, I'm considering just removing the front drive shaft and licking my wounds for awhile. Any suggestions??
Thanks!
Thanks!
