98 XLT transmission ? | Ford Explorer Forums
gatorsfan64
Ambridge, Pa
94 XLT 98 XLT
Hey guys 1st post here just bought this 1998 Explorer XLT with 4.0 automatic i believe the its the 5R55E the code on door is D fluid smells burnt Suv will only move in reverse any suggestions? Also what years of trannys will fit in there or is 1998 the only year? what i mean is can i put a 99,2000, 01 in there? i thought the previous years wouldnt fit because of gears and bell housing are diffrent. it is 4x4 has 95,000 on it only paid $600.00 tranny only problem
with a dead trans that truck is worth $600, to me still a great deal!
Have you tried a search?
a search for ? i dont know what you mean search for trannies?
OH sorry go here:
therangerstation.com and see if your door code tells you which trans you have.
I would try searching for 98 Explorer transmission, even google will bring up a ton of info.
As long as the 99-00 use the same trans type you should be allright. There are sometimes slight differences between years, so you are smart to be cautious. I wish I could be more help but I dont know the later model trucks as well...
Others on this forum do, there is alot of info here if you just try searching for it.
ok thank you for your help
