- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
I had some trouble getting it over the dowels but used a dead blow to get it on. My pan gasket at the front did tear like you’d mentioned it most likely would. The right side rubber separated from the steel but was still there. The left side bottom same. The left side top was essentially ruined and I tore the rest off. I also cut off the right top. So I lifted the steel up on both sides and squeezed rtv under it and then put a tall bead on both sides on the top. Essentially the rtv replaced the rubber on top on both sides. I drove quite a bit today and no oil or coolant leaks.
I should have just done this job a long time ago. It wasn’t hard at all. i dreaded doing this job thinking that the accessories and brackets had to be removed and I wasn’t thrilled about the thought of all that work. I was able to remove the timing cover and replace the gasket and not remove a single accessory. Removing the radiators from explorers sucks and was the worst part of the job, really.
That's exactly what I did with my oil pan gasket, the front end pieces were messed up upon removing the timing cover and inspecting it well. That's where my black one was seeping for ages before I went into it to do everything back and to the timing chain set. The factory had the luxury of bolting it all together basically dry with very little RTV anywhere. To reuse any part of it takes a lot of cleaning and careful resealing.
