99 Explorer A/C Clutch will not engage
bitterdog
99 explorer limited 4.0 s
Good Afternoon.
I have a 99 explorer where my A/C clutch wont engage.
If I jump the a/c relay pin 85 to pin 87a it will engage.
If I jump the a/c relay pin 86 to pin 87a will NOT engage.
If I jump pin 30 to 87a it will engage.
Swapped out the relay - no go
I jumpered the low side pressure switch - no go
I checked the low side harness for continuity and Voltage 13.8v
I assume the red/white striped wire is from the EATC? There is no power from it.
The black/white wire read 13.8v
I jumpered the high side switch - no go
I checked the high side harness for continuity and Voltage 13.8v also
I then Jumpered the high side harness and low side harness and still no clutch engaged.
All fuses checked.
Refrigerant levels read good when I jump the relay and turn on the compressor
Did a EATC self test - only code was for a bad blend door.
I don't know what else to check. I would greatly appreciate any other suggestions besides take it to the shop I live in Arizona and it will be 100 degrees this weekend.
Feels like I'm getting close to leaning towards the PCM
SoHK_alumni
Tampa, FL
5.0 V8 2002 Ranger
Looking at the wiring diagram, that you can jump the clutch relay at pins 30 and 87a and get power to the a/c clutch does very strongly suggest the PCM is what/where the problem lies.
The PCM has a couple specific reasons it'll turn off the A/C -- either an engine over heat, or at Wide Open Throttle.
An OBDII data reader might show the engine temp sensor is whacked out and the PCM thinks it's in over heat.
I'd suspect if the throttle position sensor had whacked out, you'd get a bunch of check engine fault codes.
One thing to check. With the engine off, key out of the ignition, do you have power to pin 30 on the relay? If not, a "semi permanent" jumper between pins 30 and 87a should bypass the PCM's control and get your A/C running.
bitterdog
Hmm you know what. I have a busted Temp Sender/Sensor on the thermostat housing.. the problem I'm having started right about the time it snapped off. Ill replace it this week and see if that tells the pcm to turn on my damn air!
And to answer your question YES there is power with the ignition off I have power to pin 30. I only need to drive the truck 10 miles a day. So I jumped it last week drove it to work.. did not take the jumper out and came out to a semi dead battery.
Thanks for your help. Ill replace that sensor and post back.
bitterdog
BINGO! Thanks for the suggestions.
I plugged the new temp sensor/sender in and CLICK the clutch kicked on!!
Thanks again.
A Explorer 2006 AC compressor clutch engaging and disengaging A/C & Heater systems - HVAC 0
S 98 Explorer A/C Clutch problems A/C & Heater systems - HVAC 1
N 97 Explorer Eddie Bauer AC Clutch not engaged A/C & Heater systems - HVAC 2
K A/C clutch doesn't work on 91 Explorer! A/C & Heater systems - HVAC 7
D The compressor clutch doesn't turn on in my 95 Explorer. A/C & Heater systems - HVAC 14
U Slipping a/c clutch on '00 Explorer A/C & Heater systems - HVAC 0
M Rear ac line help 2012 explorer A/C & Heater systems - HVAC 1
N My 2016 Explorer Platinum is overheating and the AC system doesnt work A/C & Heater systems - HVAC 0
S 06 Explorer A/C compressor cooling issue A/C & Heater systems - HVAC 0
K 2003 Ford explorer EB AC Compressor issue A/C & Heater systems - HVAC 0
B 2005 Explorer XLT - No lower heat A/C & Heater systems - HVAC 1
I 1993 Explorer 2 Door Sport 2WD ALL new A/C problems A/C & Heater systems - HVAC 2
B 1995 Explorer A/C & Heater systems - HVAC 2
Conestoga Actual Radiator replacement on 2010 4.0L Explorer A/C & Heater systems - HVAC 1
D 1999 Explorer A/C stops blowing cold when I hit a bump A/C & Heater systems - HVAC 1
C 1996 Ford Explorer AC Compressor O Ring / Seal Size / Source / Part Number A/C & Heater systems - HVAC 1
P 2004 Ford Explorer XLS - A/C Clicking on Coldest Setting - Left Side of Console A/C & Heater systems - HVAC 1
O 1992 Ford Explorer XLT Compressor issues A/C & Heater systems - HVAC 5
R 97 explorer 6cyl ac vacumn hose location A/C & Heater systems - HVAC 0
S 1994 Explorer XLT AC leak... A/C & Heater systems - HVAC 2
T 1996 Explorer AC Clicking A/C & Heater systems - HVAC 1
M 2014 ford explorer limited with rear ac A/C & Heater systems - HVAC 0
0 01 explorer blower motor won't turn off?????? A/C & Heater systems - HVAC 0
P 07 explorer, is it the blend door or is it the actuator A/C & Heater systems - HVAC 1
T 2004 Explorer Limited - Replacing HU A/C & Heater systems - HVAC 0
Y 98 explorer won't blow cold air! A/C & Heater systems - HVAC 0
R 08 explorer air conditioner help A/C & Heater systems - HVAC 10
D AC in 2010 Explorer A/C & Heater systems - HVAC 1
G 2005 Explorer AC not working A/C & Heater systems - HVAC 0
S 2001 Explorer AC Problem/Question A/C & Heater systems - HVAC 1
B 98 Ford Explorer A/C issues A/C & Heater systems - HVAC 1
K 01 Explorer Sport A/C & Heater systems - HVAC 0
F HVAC Troubles / 2000 Explorer XLT A/C & Heater systems - HVAC 0
T 2001 Explorer Sport 4.0 SOHC Vents stuck on. A/C & Heater systems - HVAC 1
D 99 Explorer Sport A/C Blowing Hot Air A/C & Heater systems - HVAC 1
P 2001 EB Explorer A/C Leaks 6Cyl SOHC A/C & Heater systems - HVAC 0
T 2005 Ford Explorer AC only Coming out one Vent A/C & Heater systems - HVAC 0
B Need a blend door cable for 1991 Explorer XLT A/C & Heater systems - HVAC 0
M 04 Explorer no heat A/C & Heater systems - HVAC 1
P 2006 Explorer XLT 4.0 Temp blend door fix ? A/C & Heater systems - HVAC 0
T No heat 1997 Explorer. A/C & Heater systems - HVAC 0
P 02 Explorer - Air/Vent control won't work A/C & Heater systems - HVAC 0
J Ford Explorer 2006 A/C not blowing at front A/C & Heater systems - HVAC 3
D New a/c lines 98 ford explorer 4.0 sohc A/C & Heater systems - HVAC 1
S A/C not cold. 2001 explorer A/C & Heater systems - HVAC 3
D 98 explorer blower stuck on high A/C & Heater systems - HVAC 3
E 02 ford explorer V6 4.0L SOHC A/C & Heater systems - HVAC 2
S 03 Explorer rear A/C mix door stuck? A/C & Heater systems - HVAC 0
H 2008 Explorer AC problem A/C & Heater systems - HVAC 1
A Explorer Air Box into a Ranger? A/C & Heater systems - HVAC 0
Similar threads
