Mike65
- December 31, 2013
- Horsepasture, Virginia.
- 2005 2WD Regular Cab F150
Just as an FYI to anyone in the rust belt states where your state uses a lot of salt on the roads in the winter that has the charcoal canister bracket above the spare tire rusted away like is the case on my wife's 99 Explorer Sport. I found a 2000 in my local pick n' pull & it had a plastic bracket instead of the metal one. Just make sure you soak the bolts very good with rust bust because it will break the bracket where the snap clip slips on that the retainer bolt goes through to hold it to the frame. I have to repair one of the bolt hole areas on the bracket with a piece of metal strapping which I will epoxy in place. I will post pics before & after the repair for anyone interested.
