joe doe
- April 10, 2003
- slatington,pa
- 2000 ex sport 4.0 ohv
are you sure you installed the stat in the correct position/direction?
it is possible to get a bad one as new too. best way to be sure is to heat some water to the opening temperature then drop the stat in there and see if it opens .
hopefully you get this figured out .
