99 Explorer reverse is park neutral is drive | Ford Explorer Forums
milesjack
1999 ford explorer
I have a 99 Explorer 2wd yesterday , out of the blue something happened to the transmission , suddenly the reverse became park , neutral became drive , and all the rest work fine , also the od light stop working it wont come on at all
what could be the problem ?
Sounds like your linkage is out of whack. With the truck turned off, I would have someone move the gear selector while looking at the lever on the side of the transmission and see if it's screwed up somehow.
This "may" help
http://www.explorerforum.com/forums/showthread.php?t=219144&highlight=shifter+bolt+floor
You might have 2 issues going on.
First, verify if the truck is actually shifting into overdrive. You should see 2000-2200 Rpm's at 65mph
Several things can cause the non responsive od light.
First, make sure the dome light dimmer isn't switched off. ( this dims the od light to invisible level during daylight)
The od switch on the end of the shift lever does fail--
There is a small thumb wheel to adjust the shift position indicator--sometimes this will break , causing the indicator to malfunction
2004 Transmission Indicator
I have a 2004 Explorer, Auto ntransmission.
The shift indicator does not line up with the gear the tranny is in. Caan someone help with describing the fix.
Welcome to the Explorer forum:wavey:
