stickboy
- June 3, 2014
- Missoula, MT
- 99' Explorer Limited 4x4
I am working on a 99 Limited 4x4 4.0 SOHC that I got from a friend for nearly nothing. Overall the vehicle is in pretty nice shape. Just needs some cleaning and a couple of little things fixed. While he still owned it, his thermostat went out and it overheated. After replacing the thermostat, there was still a lot of leakage around the front of the right head. Took it to a shop and they said it was a blown head gasket and quoted him in the area of 3k to fix. So he let me have it as a project car.
I finally got the motor torn out this weekend and started digging into the engine. After taking the right head off (and screwing up the timing...) I couldn't find anywhere on the head gasket where it looked blown. There was no water in oil, no steam in the exhaust, just a lot of water leaking outside.
You can see the stop leak, but it doesn't appear to penetrate the head gasket to the outside anywhere...
Upon turning the head over, I see this:
And finally, the thermostat housing where it bolts to the head. Note the shape of the O-ring. That is pretty much how I found it laying on the head.
So from initial examination it looks like I might still have a good head. Gonna take it to the machine shop to have them clean it, test it and check the valves. The rest of the engine so far looks really good. There is very little lip on top of the cylinders, and you can even still see some of the crosshatch from honing. Might need to see if this engine has had history...
Also, looked at the rear timing cassette and it looks really good. May not have to replace it.
