1997 Mercury Mountaineer
o front differential - Dana 35 front axle | 1.7L (3.5 pts) 1.7969 qts | manual calls for 4X4 Gear Oil, Ford part # FITZ-19580-A, Ford Specification WSL-M2C191-A.
<B></B>
- [DC] RP MaxGear 75W90 (part #01300)
- Lucas 75/90 Synthetic Gear Oil [LOP-10047S]
snip...
Actually, 95, 96, and 97 all call for the same part number you mentioned.
Starting in 98, they specify, "Motorcraft SAE 80W90 Axle Lubricant' but don't cite a specific Ford part number or spec.
For '99, they call out 'Motorcraft SAE 80W90 Rear Axle Lubricant' which was likely the same as 98.
For '00-'02, they call out 'Motorcraft SAE 80W90 Premium Rear Axle Lubricant'. The label probably just got bigger.
Ran out of time to check later years... maybe tomorrow...
-Joe
What about the front diff? Same stuff?For '00-'02, they call out 'Motorcraft SAE 80W90 Premium Rear Axle Lubricant'.
I thought all the failers were from the bearing being made in China by a little 5 year old boy named ching-chow-chang, where he manually forms the bearings out of playdoh and paper mache for 3 cents a day?avoid 75W140(for the rear axle) even though it may be suggested...In the past few years Ford had lots of differential failures. There are examples on this board...Does this have anything to do with 75W140? Maybe.
... Looks like I have a leaky output shaft seal on the passengers side from axle.
