jwilson61
- January 16, 2009
- my mom and dad
- 99 ranger
I have a 99 ranger 4.0 4x4 5r55e trans 106000 miles that Im having a horrible time trying to diagnose a problem on. starting and driving cold the trans works as it should but after approx. 12 miles the od light starts flashing and the shifts get harsh till I shut the key off and reset the pcm im getting a code p0741 so I replaced the tcc solenoid and nothing changed replaced the valve body with a new one with new solenoids the problem got worse and more frequent I m noticing on my scan tool that the temp sensor is reading 287 degrees yet i can hold my hand on the pan no problem I dropped the pan and got the valve body wire harness off and in the cool air and the trans temp still read 158 degrees, yet Im not getting an overheat code just this 741 code can the high reading on the temp thermister cause my problem even though a codes not being set for it when warm. Im pulling what is left of my hair out trying to figure this out .. fluid is bright red no friction material in pan readouts on scan tool show lockup until up to temp and at least 12 miles ...any ideas as to where to turn Thanks in advance and sorry so long a letter
