Caleb33
- September 4, 2012
- Orlando
- 2002 ford explorer
So my ac as been blowing a bit weak on all fan settings so I figured the compressor was starting to go and was weak. I took it in to get looked at they and they tested the pressures off of the compressor and it was perfectly normal.
The air that comes out of the vents is very cold it just doesn't blow fast, however you can hear the fans turning which makes me think there is some sort of blockage in the system.
Has anyone else had this problem and is it possible that it could be the little flap that controls where the air gets directed isn't opening correctly?
2002 xlt 4.0 sohc
2002 xlt 4.0 sohc
