thh
- December 31, 2013
- 1999 Explorer
My 99 explorer (Eddie Bauer) is running the ac system at high only. Entire a/c & heat system will not turn off either. Since this is an Eddie Bauer, it has the automatic temperature control system (atc) in it. When I first got it back in November I had a similar problem which I fixed with a new atc resister module. The difference is in the previous issue I could shut the system off or use either high speed or blower completely off. The dash fan switch is bad and recently the fan button on the steering wheel had started acting up as well (when pushing the switch for lower speed it would sometimes increase speed instead). Other than that it has been working well. Any thoughts ? Car is 4 liter sohc with 211,000 miles.
