A/C - Defrost - Vacuum - what to check next | Ford Explorer Forums
davem
Rochester, MN
'01 XLT
I've read several posts about how a vaccum leak will cause the a/c to blow through the defrost vents. Under load, such as driving up hill/heavy accelleration, my AC will blow through the defrost vents.
A repair shop examined the vacuum lines under the hood, including to the cannister/ball, and thought they looked OK. Next they want $50 to run a 'smoke test' to look for a small leak somewhere. They also want to check the exhaust for a 'back pressure' issue, somehow affecting vacuum.
Is there anything else I can check myself ? Some unit under the dash/near glove box ?
Its a 2001 Explorer XLT, V-6, with 77K miles.
Runs fine, AC is good under normal load, and no engine codes.
Any help is appreciated.
Thanks.
Dave
where is the control switch ?
Where is the control switch ? What does it look like ? How do I 'test' it ?
Dave
Dave
the thingy you turn to adjust the function--right below the radio silly:D
where is the servo piston ?
where is the servo piston(s) ?
(Sorry, need a lot of help)
