Clutch Cycling Pressure Switch
The clutch cycling pressure switch is mounted on a Schrader valve-type fitting on the side of the suction accumulator/drier assembly in Aerostar vehicles, and on the top of the suction accumulator/drier assembly in Ranger and Explorer vehicles. A valve depressor, located inside the threaded end of the pressure switch, depresses the Schrader valve stem as the switch is mounted and allows the suction pressure inside the accumulator/drier housing to control switch operation. The electrical switch contacts are normally open when the suction pressure is at or below 169 kPa (24.5 psi); they will close when the suction pressure rises to approximately 300 kPa (43.5 psi) or above. Lower ambient temperatures (below 8°C or 46°F), during cold weather seasons, will also open the clutch cycling pressure switch contacts due to the pressure/temperature relationship of the refrigerant in the system. The electrical switch contacts control the electrical circuit to the compressor's magnetic clutch field coil when the function selector lever is set for air conditioner operation. When the switch contacts are closed, the clutch field coil is energized and the air conditioner clutch is engaged to drive the compressor. When the switch contacts are open, the compressor's magnetic clutch coil is de-energized, the air conditioner clutch is disengaged and the compressor does not operate. The clutch cycling pressure switch, when functioning properly, will control the evaporator core pressure at a point where the plate/fin surface temperature will be maintained slightly above freezing, which prevents evaporator icing and the blockage of airflow.
