areonic1
- July 6, 2010
- Crappy, Alabama
- 1993 XLT
Ive been to this forum alot, but never reg/posted so i wasnt an annoyance, but things just keep getting worse in my situation. Alright, It might be a little lengthy, but I want to give as much info as possible to prevent back and forth, and sorry if it seems Ive bounced around...
1993 Ford Explorer, Limited
I bought the car about a week ago, and the owner said the only thing wrong with the AC system, is the clutch wont engage and it needs freon. So read up a lil, found out how to test the clutch bypassing everything. Clutch worked, and it had 0 freon in it, so i thought the sensor wouldnt let it kick in with no freon. Filled it up with freon, clutch engaged, seemed to be getting better, turned car off, heard leek, was coming from the pully shaft on compressor.
Bought new compressor, bought more freon, filled it up again, started blowing ice cold, all of a sudden, i burst of sound, like pressure relief or a BOV from a turbo...now its empty on freon again. Figured I put too much, tried again, filled it up just enough to where the clutch would stay engaged, instead of going in and out, time it stayed engaged, i stopped. Seemed to hold, put it in gear to test drive, everything blew out again.
Now I take it to a repair shop, they say the dryer thing, and orface tube needs to be changed, I bought the parts, payed them to put it in, (this is all coming from what they say) The original orface tube was put in wrong, they had to put oil in and what not to get it out. Put new stuff on, ac blew cold for a few mins, they drove it down the road, warmed up and no more cold air. THEY CLAIM ITS A LEAK. I asked for proof, How do you know its a leak etc....They said the system was at 35psi, and now its at 20..an hour goes by before I get there, so if theres a leak, it would be even lower. I asked to put a meter on it, to see if it went lower, they refused and argued its a leak. I dont believe it at all. They even went over it with a sniffer in front of me and it never beeped.
I take it to a different shop on the way home, really upset i just blew money and in a worse situation. He checked the pressure, its 90+ when the ac is turned OFF, but as soon as the clutch engages, the pressure drops down to 20 for some reason. He said theres no leak, since the pressure was fine when its not on. Something about its pulling a vacuum on the low side or something. That the first group might have put something on wrong, or what not.
Now later in the day, someone told me, that something similar happened to them once, and its cause garbage was in the lines or something and they blew it out with an air compressor and it started working fine. That a clog could cause my problem.
My problem is, I dont know much about ACs, but I can do alot of other stuff with working on cars. I really cant afford to drop alot more money on something I can do, if i knew what to do. Like today, I could of saved $200, just by standing in front of my car for 8 hours, swapped a part that took 30mins and screwed it up. I would really appreciate ANY HELP at all on this, cause Ive already gone through 600bux and I cant afford it to keep going. AC isnt a big deal, until i try to drive with my 4 and 1 year old in the car.
Thank you in advance!!
EDIT!! Its an Accumulator and orface tube that got swapped, not a dryer.
