98EdBomber
- January 5, 2011
- Las Vegas, NV
- 98 E.Bauer 4.0(RWD)
Recently replaced the thermostat housing because it was leaking. I have driven it for 2 days and no leaks. Thermostat new as well. It will start and run fine in the morning and heat up normally and stay in the "middle" of the temp gauge.
Within the last two days it has been 105* F and this is when the problem occurs.
During the morning commute it was only around 78*F and I had the A/C on HIGH the entire trip just to test it (even though i didnt need the A/C). The commute is about 30 minutes or so. While A/C on HIGH, I had no problem whatsoever the entire trip.
In the late afternoon (4pm) it was 105*F and about 25 minutes into the trip with the A/C on HIGH, the engine temp SLIGHLTY raises just past halfway and the engine idles at around 1200 rpms or so and the idle is definitely a little shaky. Normally at around 750 rpm. Mind you, this only happens when I end up in stop and go traffic or sit at a stop light for a while. The temp will go back down when I start driving again and the idle sometimes goes back down if I drive for a while. Then if the compressor is still on, the problem will come right back. If I drive with the compressor OFF, it never overheats or raises idle. Purrs like a kitten actually.
Also, in the morning the rpm doesnt increase much with the A/C on High. I can hear the engine rumble a little when it turns on and it adjusts the idle and settles down a bit. But the idle definitely is a little rough when the A/C is ON. With the compressor OFF, the idle is pretty smooth.
When the compressor is engaged, the plate clicks but it sounds like the bearing is going out. Makes a dull grinding sound. Just had the A/C freon recharged last month with exactly 30 oz. This issue has all of a sudden started when it got over 100*F.
Could a bad A/C bearing be causing this odd over heat/high idle condition or is it something else in the cooling system?
Hopefully someone has had this issue before. Thanks for all the help if you can.
T-
EDIT: I have an OBDII scan tool that has live data. If I hook it up while this condition is occurring, is there any information that could help point to the problem?
T-
