JakePSD
- March 25, 2010
- Ohio
- 2003 Mercury Mountaineer
I tried searching but couldn't find what I was looking for. My truck has open 3.55 gears. I hate open diffs with a passion and would like to convert it to limited slip.
I have a parts truck that., according to the door sticker, has 3.73 LSD gears. I don't tow much so I'm ok with the higher ratio I currently have for better fuel mileage, and on the rare occasion I do tow something heavy, I do so accordingly. It doesn't have the tow package but I put the bigger on a bigger hitch from one that I'm assuming did.
Can I take the LSD carrier out of the parts truck, bolt my ring gear to it, and put it back together? Would i have to change the pinion gear also? Or would I be better off swapping both front and rear diffs and have the 3.73's?
Are all the front diffs open? Or did they make them in LSD also?
A side question, other than the 3.73 LSD gear and bigger hitch, what difference is there between tow package and non?
