pickardracing
- September 17, 2004
- Manitowoc, WI
- 91 XLT
First off, id like to say hi , my name is Mick and I recently bought a 91 Explorer XLT. Ive got a few issues that id like to ask about.
1. The other day i got a CEL. I pulled codes on it and they came up 77 and 74. I dont have the book on the scanner anymore and couldnt find what they were.
2. When you start it in the morning, it starts hard. It hardly ever starts on the first try. I turn the key for 3-5 seconds, stop, try it again, and it usually starts within 2 seconds. Juust doesnt want to fire right up. I just gave it a full tune up in fall.
3. When going down the road, i can hit the brakes, and ever so often theres a clunking noise in the front end when the brakes are depressed... i have no clue on this one.
4. This truck has manual Warn hubs. Is it safe to daily-drive the truck with the hubs locked? and are the hubs supposed to click when you turn them to 'lock' or do they only click when you turn them to 'unlocked'? Mine do not click into lock.
5. I replaced the front shocks on the truck when i bought it. Where the bottom of the drivers side front shock connects, there is a misshaped oblong hole in the arm where the bottom shock bolt goes. it's also a different bolt and nut setup than the psgr side. Im thinking this is some sort of backyard engineered setup. little help there would be good.
6. The 4x4 engages when it wants to, and i cant seem to get Low Range to work. i do hear a bunch of clicking from behind the drivers side rear panel. wtf.
7. Power locks work fine with the exception of the passenger front. What could be the issue here? i hear no noise from the door when the button is hit.
7. Last but not least, this thing shakes and rattles like a bear at 65. I balanced the tires and checked out everything i could visually inspect, but this is my first 4x4, and i have no idea what to look for.
Sorry for all the questions at once but i figured i wouldnt litter up the board with multiple posts. Im new to the Explorer/4x4 thing. Hope to stick around for a while. I really like my truck and hope that i can fix it up a bit and have it be something to be proud of.
Thanks in advance.
Thanks in advance.
