huntman58
- February 13, 2007
- Fremont calif.
- 2013 Dodge Advenger
Okay out side temps only in the low 70's going up hill on pavement temps hit 200 or better and when off reading same weekend low gear low 4x4 up hill hard climb temps got to 250 plus and in fact pegged the needle on my mechanical sunroof gauge ( marked from 100 to 250 deg’s). The temp probe is installed right before the line go's into the radiator in the tranny line but before it hits any of the coolers. Same set up as ExploringNC Installing a Transmission Temperature Gauge write up.
From reading I take it this is also when the oil is at its hottest point as it’s from the converter also and not what the whole tranny is seeing.
So is this way to hot and would a larger external cooler help this? I do have the stock cooler now on it but its small. Now going down the HWY the temps are about 140 to 150 with out side air temps in the high 50 to just hitting 70 deg F.
I do not want to burn this tranny up as it costed too much to have rebuilt and I need it to last a few more years so any real world help or input is greatly wanted and thanks for it a head of time
