91Explored
- September 20, 2010
- Austin TX
- 91 Explorer w/A4LD
Had forward only in OD and NO reverse. In neutral would roll forward but not reverse, had to put drive shaft to move in reverse. When I tore the transmission down the input shaft grooves at the torque converter were slightly twisted but could remove torque converter. The other end of the input shaft also was twisted and the inside of the OD Planetr was stripped out. I had to use a punch to remove the shaft fron the OD Planet. It the OD band was mostly 80 % dry. The question is would this be the pump failing causing this to happen???
Thanks
Thanks
