Zinj
- March 10, 2009
- lake hopatcong,nj
- 1993 ford ranger
Some quick advice needed. Putting in an a4ld in my 1993 ranger 4x4. I've
noticed the govenor in the one I'm putting in is "under" the output shaft
and the one I took out is on the right side of the shaft looking in. Is one of these wrong or does hydro pressure hold it against the shaft so it doesn't matter? Also ,quick ? What's better: bolting the torque converter to the
torque plate first and than slipping in the trans., or putting the converter
onto the input shaft and lining up the converter bolts into the plate and slipping it on as a unit? also, any real concerns about balance between different trans. and converter with the orig. torque plate? thanks. I'll be looking for the info.
