429CJ-3X2
- November 6, 2009
- Des Moines, Iowa
- '01,'02, '04 Sport Tracs,
My son was driving his '97 Mountaineer 5.0 today when the lower idler pulley failed - the grooved one below the tensioner. It's been chirping for a long time, but seemed to lessen as the engine warmed up and I hadn't figured out which pulley was making the noise. I know now! The outer part of the pulley and the bearing have separated.
Question #1, someone who stopped to help thought maybe the water pump had locked up, but it spins freely by hand with the belt off. It does make a bit of a rubber on metal squawk just as it slows to a stop, but is otherwise quiet. Is this cause for concern?
Question #2, The a/c system has a huge leak somewhere and therefore doesn't work. The serpentine belt survived the idler pulley failure, but I'm going to replace it. Would it be wise to replace the belt with the shorter one that eliminates the a/c compressor?
