- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
I know I'll figure this out as I get into it, but are those tangs/hooks/clips the only support for the condenser? I'm trying to think through mods to make this easier if I have to remove & replace the radiator again in the future. This Mountaineer is in above average condition with a small spot of rust at the top of one wheelwell, and surface rust on the front bumper. Has 161,000 miles. It had 133,000 when we bought it 8 yrs ago next month, and the previous owner was a mechanic who applied some sort of homemade rustproofing. Although it is my son's, it's registered in my name and when he decides to get something else, I plan to keep it barring an accident or some catastrophic failure.
Yes, those plastic pieces are all that hold the condenser in place. The V6 bracket will mount to either condenser, so that you don't have to change. I think the others who did that upgrade used a V6 radiator, but it also likely had the half thickness core. So I think the V8 radiator is probably best to use, as it does mount forward more than the V6 unit. I could have done that myself in 2006 if I had heard of it, I liked that V6 bracket when I was rebuilding my 99 SOHC truck. But I don't have the V6 bracket yet to do it, that's another item I need to put on my list.
