a4ld vacuum line question | Ford Explorer Forums
Fordexplorerguy1
NC
94 XLT 4.0 tow package?
Okay so I have an a4ld that i have to rev up to 2300-3200 rpm to get it to engage into any forward gear and i have to let it sit when i put it into reverse and it randomly engages. My question is: Is the picture of that cracked vacuum hose would that cause my issues? or would it be something related to the valve body? Either way i replaced that hose and tomorrow i plan on checking the modulator too and replacing that hose if its brital or if it has fluid in it ill replace the modulator
any input will be greatly appreciated!! thanks!
Ah, ok so what else can i do to help with the slipping, and not going into gear?
how do you adjust the kickdown cable?
