About my exhaust | Ford Explorer Forums
About my exhaust
02EBEX
VA
02 Eddie Bauer V6 4x4
all i have done is a 50 series delta flow muffler. Is there any thing else i can do that'll help my gas mileage.
its just a flow master muffler with everything else stock
any ideas would be great!!!!
Tune Up, Keep your oil changed on the dot every 3k, KN filter, keep your RPM's to less than 2600 at all times (4.0), I switched to mid grade from regular and got a decent bump in mileage (.5 miles to the gallon) according to my math and the truck.
I would say a better flowing exhaust and headers would be another good way to get better mileage, but for the money it wont show you the improvements you want.
Do what I did, buy a car.... (Trucks a toy now)
-Jeff
1. I would suggest looking into a K&N Intake or KKM or similar, this will allow the engine to inhale more air, which will give you a bump in HP/TQ as well as better MPG ( est. 1 to 2 miles increase ). also it will make the muffler sound better...
* the K&N intake on an 03 X dyno'd ( + 7.5 HP ) on K&N's website...
2. Another suggestion would be remove the exhaust resonator just before the muffler, this will free the exhaust up some more, if you havent already removed it...
* may sound silly but, cut off the tail pipe where it makes the final turn to run straight out the back. then have a 45 degree exhaust exit. It's just one less bend in the exhaust which means better flow...
3. Run Synthetic oil, promotes smoother running engine...
4. bottle of fuel system cleaner once a month doesnt hurt...
5. try running 89 octane over 87, i am and it make a hell of a difference...
6. run larger exhaust piping ( 2.5'' pipe )...
7. proper tire pressure...
8. Change your transmission and center diff fluid...
9. tune from james to adjust for the larger tires...
** I have done everything on this list with the exception of # 9. And it has made a difference in performance, as well as MPG's
What kind of mileage are you pulling with all that Caldwell? I drive relatively aggressively city/freeway mixed and pull 16-17.
I found with my MAC exhaust (2.5") its killed all my low end ( which is where all the power is on a 4L Explorer is) Im wishing for my old stock exhaust back...
I do 90% of my driving in stop and go traffic...
when i had My Red X I was getting roughly 15 to 16 MPG ( in town )
I had the following done to it...
K&N Intake / 2.5'' FlowMaster CBE / trans fluid change / fuel system cleaner / 87 Octane / Non Synthetic Oil
now with my Silver X im getting about 15 MPG ( in town )
I have the following done to it...
K&N Airbox Mod / Magnaflow Muffler / fuel system cleaner / 89 octane / Non Synthetic Oil
* i havent made the switch to Synthetic yet with my new X, but will on the next oil change. Im hoping to see a small gain by making the switch. also i would see more mpg gains if i run 2.5'' pipe instead of the factory 2.25''. i wanted to see how well the muffler would perform on its own. i may upgrade to 2.5'' pipe later on, but im happy for the time being. Also prob ably in the middle of the summer i will have the transmission and diff flushed with fresh fluids
BAJAXPLORER - yes you lost low end TQ, but i bet your X pulls like a **** even well into the top end ? with the K&N INTAKE, and 2.5'' EXHAUST my X pulled pretty hard thru the top end
CALDWELL,
you are correct- top end is great pulls well but I dont usually drive in the 38-4800 rpm range, most driving is at 22-2400 rpm in 5th gear on the freeway. so even though yes I technically get better freeway mileage, I do 90% of my driving in town, and thats where id like to have the mileage. Its a give/take situation with the exhasut. It probably would have been better for me to cut out the bulky stock muffler and weld in a replacement one, live and learn I guess..the wallet is lighter about $250- but it works decent, fit sucks on the MAC- someday I will get a replacement.
thats what its all about fella, trial and error...
