- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
OK I have played with the cold air induction on my 88 BII about 5 times now. The first setup was easy, cut a big hole in the side of the airbox and put a speaker grill over it. Minor gains.
2nd attempt I simply put a K&N cone on the end of my 2.9L's intake tube. More gains, lots of growling at WOT.
3rd attempt was the same thing, except this time I built a new intake tube from 3" PVC and wrapped it with the heat protective tape. Worked very well! I gained a few MPG and a little more HP over the other setups.
So now what? Working good but I wanted more.
Well I eneded up cutting a 4" hole in the radiator support just below the battery tray. I used the stock intake hole location as the starting point and a cremmel to cut the hole. Patience is key here, that hole was a bitc* to cut! Not to mention I had to remove the push bar, bumper and grill. Then I sprayed the area with rustoleum black paint to keep the nasty rust away....
I used a 4" PVC toilet drain to floor flange adapter on the inside of the hole and attached a 4" piece of industrial strenght dryer hose to it. Not the white stuff and not the aluminum stuff, this is heavy duty black plastic tube witht he spiral spring inside it. Works perfect. It runs along the bottom of the battery tray, up near the AC purge canister, and then makes a 180 u turn around to mate up with the K&N 7" cone. You can see somer pictures of this setup on my website....
OK OK so now you guys are like "what does a 2.9L ram air setup have to do with our MAS 4.0L's???""
Well I ditched the 2.9L in favor of a 94 Explorer 4.0L. I'm just about the happiest person alive. What was I thnking toying around with that 2.9L for all those years when I could of had the 4.0L all along!!!
So far I have JBA's, a 16" electric fan, and my old 2.9L exhaust (2.25" cat back, Dynomax). When I did the swap I wanted to keep the airbox this time since I needed a place to mount my MAS and I didnt have the $$$$ for the KKM.
So I got a 94 Explorer K&N and threw it in the airbox. Works pretty well. Now that I have all the bugs of my 4.0L swap worked out it's time to get down and dirty with the intake on the 4.0L.....
Here's what I have done so far:
1. Got rid of the stupid air muffler, replaced with 2.75" stainless exhaust pipe.
2. Cut the intake hole inthe airbox open about 2" all around, I stuck my 4" cold air feed tube in there and glued it together.
Vast improvements over stock.
However next I'm going to replace the entire intake tube with a Ford insulated Turbo down pipe for a diesel, fits perfect as far as I can tell and it's already insualted!
Just need to plumb in the crankcase vent and wa laah.
So now what to do with the MAS and airbox?
I am planning to go back to my ram air setup, Without buying a KKM tru rev. I'm planning to fabricate an adapter for the MAS (stock MAS for now) so I can stick my 7" K&N on the end of it. Then the 4" cold air feed tube will need to be routed over the cone filter to get the ram air effect.
This means the Optima must be moved.
So anybody got any ideas on how and where to re-locate my battery?
Pictures of all this stuff coming soon....
And oh by the way is it ok with you guys if I post here?
I mean I drive a 88 Eddie Bauer BII but the interior is from a 97 Explorer and the drivetrain is from a 94 Explorer....
Thanks!!
Just thought I'd share....
Thanks!!
