ABS Code C1198 | Ford Explorer Forums
ABS Code C1198
Mauriced10
Las Vegas
1997 Explorer-Eddie Bauer
Have a 97 Eddie Bauer with the 4.0 SOHC and got a C1198 ABS code and replaced the ABS sensor on the Differential just in case before knowing the code. Anyway, anyone know or have a good fix for the problem other than a mechanic
C1198 has to do with left front isolation valve which is part of the HCU(hydraulic control unit). Unless you have a wiring problem the HCU is bad.
thanks, found out that the abs control module was bad as the negative ground affected the module and having that replaced
