Darian Key
- November 19, 2013
- Reford, MI
- 1997 Ford explorer
My front wheel bearings were bad both inner and outer on each side and before I replaced them it would buzz and pulse the peddle only in REVERSE when I got down to 3 mph or so while braking obviously. Now I replaced the wheel bearings and that does the same thing but now in drive. Every single time I drop down to about 3 mph while braking it pulses the peddle then buzzes and dims the lights a little. What could this issue be? I might just unplug the fuse because I don't like abs anyway but I still would like to know what's causing this. My brake pads are new, fluid is full, brakes perfectly fine even when abs module is doing its thing. 97 explorer xlt 4.0 ohv 2wd
