itzbinnice
- May 14, 2001
- Long Island, New York
- 95 Xlt Black
On my 95 XLT the compressor is not engaging.
Two years ago I had refrigerant added (66.00) by a local shop and the AC worked fine all summer. Last year turned the AC on in the summer and again no cold air and the compressor did not engage. This time the same shop charged me 103.00 to add refrigerant, he also checked for leaks and there were none according to him.
Yesterday I tried the AC for the first time and again compressor not engaging so no cold air. I suspect low freon again and that's why the compressor not engaging. I do know that the compressor engaged during the winter when putting in heat or defrost mode, it always does that and was designed to do so.
What stumps me is now if I put in in heat mode the compressor does not cycle.
I'm not sure if it shouldn't do that since it's 75 degrees out or because it also needs the correct amount of freon to cycle on.
The power distribution box has no fuses or relays, the only fuse I could find was fuse 18 in the fuse panel indicating AC system. Checked the fuse and that was good. I also disconnected the two wire connector to the compressor and checked with a test light, there was no power.
Does anybody know what other tests I can perform to rule out the compressor being defective and advise if the low freon will not cycle the compressor when in heat mode. Maybe a charge will solve the problem.
Either I'll find a different AC shop or bring the KY jelly with me if I go back to the shop I've been to previously.
BTW my neighbor had one of those gauges that comes with the do it yourself charge kits. I put the gauge on the low side and it showed 35 PSI, don't know how accurate that is though.
