Like this.
and just for more clarification, The above pic is setup to rotate counter clockwise. That trick does work really well. I use this method almost every time I work on something. That way I don't have to use near as much muscle. Also, normally this is done with a pair of combo wrenches (open on one side and boxed on the other)
However, for the accumulator, your going to need to use a wrench that is open on both sides as the working wrench and the combo wrench as the leverage wrench
~Mark
~Mark
Mark, CCW doesn't mean squat if you can't see the working end of the wrench (the head of the bolt or whatever could be going into the wrench from either side.) That is a great trick in a pinch. I've been using that one forever.
It never ceases to amaze me how many people try to do stuff like this without the two most essential tools: A big ass mallet and an assortment of cheater pipes of different lengths and diameters. As for this particular job, the best thing around is a homemade flarenut wrench. Get a good quality 1-1/8" or 28mm box wrench and cut a gap in it (Dremel, etc.) that's just wide enough to slip over the skinniest part of the tube. I've done that many times for oil cooler lines.
Ok just though I'd update this. I finally got the right wrenches and still no luck. It's probably just a lack of strength/leverage on my part. So I'm gonna call a few shops and see if they can help me.
Thanks for all the help I did learn several good tips from this thread I'm sure will come in handy.
You sure you're twisting the big nut (and not the smaller welded fitting?)
Yes I'm twisting the right fitting and you have to twist both anyways so you don't break the hoses. I think it's just my lack of strength I'm no where near the strongest person never played a sport in my life and only recently got into do mechanic work our of necessity to save money.
τ = r X F
