Adjusting Headlight | Ford Explorer Forums
Adjusting Headlight
TRAIL_BOSS
How do you adjust the headlight on a 93.I did the warrior shackel lift and now the beam is to low thanks.
The adjusting screws are under the hood at the back of the headlight. The one closest to the fender is for the up and down adjustment. The other is left to right.
A horizontal line should marked on a wall same ht. as center of headlights assuming the vehicle is level and vertical line at the center of both. Back it up 25 ft.
Low beam(center of beam) should be 2" lower than than the horizontal and 2" to the right of the vertical line.
High beams should be just below the horizontal and centered the same place as the low beams. It is more important to have the low beams right on since these are used more than highs.
