MNgopher
- June 30, 2008
- Lakeville, MN
- '21 Explorer XLT
Vehicle in question is a '97 Explorer with the 4.0SOHC and 5R55E transmission. 181,000 miles on original transmission, no rebuilds etc...
O/D light started flashing last week. Pulled code and shut off flashing light. Drove the X again for a few more days with no issues, but the O/D lamp started to flash again yesterday. Pulled the P0741 code again.
Transmission shop noted that the tranmission is driving fine (other than the code), fluid is in excellent shape and at the proper level.
The common link between the two events was high/warm outdoor temperatures and heavy A/C usage. In both cases, the A/C was on "MAX". The temp guage did not indicate any overheating or noticeably change from normal (though we all know what sensitivity is there is not great). At idle, the engine was occasionally raising its RPMS to 1200 or so, I'd assume in an effort to get the cooling fan to do more work.
Advice for now is to continue driving while avoiding long trips that would benefit from TC lockup. Monitor RPMS and relationship to issues with temps.
Any thoughts or ideas on where to go next?
