jw42
- September 22, 2010
- olney, il
- 1991 ford ranger
Hi. I am new at this but have found some good information.
My question is about a4ld transmissions. I have a 91 ford ranger 3.0 with a trashed trans. I am trying to use a trans out of a 4.0 aerostar. This trans has shifting problems. I am in the process of putting a Transgo jr shift kit in. The 3.0 trans had a return spring in reverse servo and 2 pucks in valve body. The 4.0 trans had no return spring and no pucks. The transgo kit says to use provided pucks. It also says to replace spring in the servo and not to use the wire clip. It also says not to forget the return spring on servo. I don't know what year the 4.0 is but the valve bodies seen identical except for the omission of these parts. I would appreciate any info. Thanks jw42
