jremington59
- October 28, 2009
- Watertown, NY
- 1997, 99 and 2000 5.0's
I recently purchased a 2000 Limited with the 5.0 engine. I noticed yesterday when I turned the key on it turned over once before I turned the key to crank. Today I went to start it and it barely turned over. I tried again and noticed the smell of burnt wiring. I popped the hood and the neg battery cable was smoking. There's a sticker under the hood that says the vehicle has a command start remote car starter and to turn the switch under the dash to off before working on it. I looked and the switch was on so I shut it off, but it still was drawing heavy and wouldn't turn over. I checked the battery voltage and it said 6.5 volts with both terminals off but with both terminals connected and the key off it read 500 millivolts. So something is drawing heavy. Figuring it was the remote starter I cut the wires at the switch but this made no difference. I pulled all fuses one at a time and this did nothing so I believe there is a direct power short somewhere. Could it still be the remote starter or would the problem be in the switch itself? It got dark so I can't look for the remote box tonight but I'm guessing it's best to find it and remove it. Any suggestions regarding this will be appreciated.
