Originally posted by MikeP
. . . The TSB will say on it whether it is to be paid by Ford. At first I did not understand these TSB's and paid for repairs that really should have been paid for by Ford. . . .
I don't know which TSBs you have that are paid for by Ford, but every one that I have printed out (20-25) has stated that the only time Ford will pay for the repair is if the vehicle is still uner warranty. The camshaft tensioner TSB is one such TSB and unless you are still under warranty or have a very nice dealer, Ford will not replace it at their expense. If you are not under warranty, Ford will charge 1.8 hours of labor to replace the tensioners and o-rings. The original TSB for just the tensioners allowed for 1.6 hours and was only elegible for coverage under the original bumper to bumper warranty. If the TSB has a statement such as "WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage", Ford won't repair the item at their expense if the warranty has expired. Here's the text:
Knocking Noise From Left Side of Engine at Start Up-4.0L
Article No.
99-26-5
12/27/99
^ ENGINE - 4.0L SOHC - "KNOCKING" HEARD FROM
LEFT HAND SIDE OF ENGINE AT START UP
^ NOISE - "KNOCKING" HEARD FROM LEFT HAND
SIDE OF ENGINE AT START UP - VEHICLES WITH
4.0L SOHC
FORD:
1997-2000 EXPLORER, MOUNTAINEER
ISSUE
A "knocking" noise at start up for up to 2 minutes from the left hand front chain cassette area may occur on some vehicles. After engine shutdown, the tensioner oil supply gallery empties. The noise may be due to air entering the left hand tensioner when the engine is restarted.
ACTION
Replace the left hand camshaft tensioner with a revised Tensioner Kit. Refer to the Instruction Sheet within the Tensioner Kit for service procedure details.
WARNING THE XU2Z-6K254-AA TENSIONER KIT IS FOR INSTALLATION ON THE LEFT SIDE OF THE ENGINE ONLY. INSTALLATION OF THIS KIT ON THE RIGHT SIDE OF THE ENGINE MAY RESULT IN ENGINE FAILURE. IF A TENSIONER IS NEEDED FOR THE RIGHT SIDE OF THE ENGINE, USE KIT XU3Z-6K254-BA.
PART NUMBER PART NAME
XU2Z-6K254-AA Tensioner Kit - Left Side
XU3Z-6K254-BA Tensioner Kit - Right Side
OTHER APPLICABLE ARTICLES: NONE
OPERATION DESCRIPTION TIME
992605A Install Camshaft Tensioner 1.6 Hrs.
Kit
DEALER CODING
CONDITION
BASIC PART NO. CODE
6K254 42
OASIS CODES: 497000, 702100
