quick2scramble
- June 16, 2009
First a bit of info on what was previously done.
Dealership replaced lower ball joints (driver and passenger) and then did an alignment. After this was done they went to do a state inspection and said the upper control arm (not sure what side) had some play and would probably require replacement within a year. Service director said I should probably have it replaced now so I gave the go ahead. Got a call that the UCA has been replaced and asked if they redid the aligment. Mechanic said an alignment isn't required because it's a stationary control arm. I did a some searching and everything I'm finding says anytime a UCA is replaced an alignment should be done. I'm wondering if this applies to the 'stationary control arm' the mechanic is referring to as well.
Short Version:
UCA replaced. Mechanic says UCA is stationary and therefore doesn't require an aligment be done. Is this correct or should an alignment be done regardless?
Thanks in advance.
Short Version:
Thanks in advance.
