- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Hey! Just wanted to share some stuff I found out with you guys. Here's the deal:
I have a Duff 3" lift, drop brackets for the beams, coils, and shocks. I recently installed the F-250 spring seats from Ford which lifted me another 1-5/8" up front. I also installed some Skyjacker radius arms. So after all this I took her in for the alignment and they installed some 2 degree shims, brought it real close to correct but I was left with some + camber. The + camber is wearing out the outter edges of my tires big time.
So I start looking for solutions. Apparently the largest shim available for the D35 (92 X) TTB is 2.25 degrees which wouldnt be enough to fix the + camber.
I heard some rumors of a 3.5 degree shim made by Superlift, that turns out to be false, Superlift offers 2.25 max.
Since I am running approx 5" of lift with only 3"drop brackets I am right on the edge, meaning I could either drop the lift down a littlewith smaller coil spacers, or install 4-5" drop brackets for the axle beams. NO way. I want the lift the way it is for a reason, I got the strong Duff brackets, the Skyjacker arms, and the 3"coils. So I start looking into other options.
Bent beams would fix me up perfect, however thats a little pricey and will come down the road. I did a little research and found that indeed somebody out there does make 2.75 degree shims for the D35 front end....
Perfect! + camber is gone.
So maybe this will help some people with similar problems.........
