alternate A/C compressor? | Ford Explorer Forums
tweakedlogic
memphis, tn
'92 XLT
A/C compressor died. refurb is $260. That's too much money for me right now.
I was hoping there was a late model car or truck with a compatible compressor. Any suggestions?
There may be, go to a good parts department and have them cross the part number to another application. The people at Advance auto or auto zone may not be able to do this. I would go to a ford dealer and ask them to cross it for you. If they can't then an A/C shop should be able to help you.
There are aftermarket companies that make kits for the Hot Rod people, they may have info for you as well.
According to Hollander Interchange, these will be suitable donors.
Integral A/C:
BRONCO 90-91 integral AC, exc. keyed shaft; (FX15), 8 cyl
BRONCO 92 integral AC (FX-15), 8 cyl
COUGAR 89-90 w/o supercharger
EXPLORER 91-93 integral AC
FORD F150 PICKUP 90-91 integral AC, 8 cyl, w/o keyed shaft; (FX-15)
FORD F250 PICKUP 90-91 integral AC, 8-302 (5.0L), w/o keyed shaft; (FX-15)
FORD F250 PICKUP 90-91 integral AC, 8-351 (5.8L), w/o keyed shaft; (FX-15)
FORD F350 PICKUP 90-91 integral AC, 8-351 (5.8L), w/o keyed shaft; (FX-15)
MAZDA NAVAJO 91-93
RANGER 90-93 integral AC, 6-245 (4.0L)
RANGER 92-93 integral AC, 6-183 (3.0L)
THUNDERBIRD 89-90 w/o supercharger
Notes:
- Rear line mounts
- Compressors are available with 16 or 21 splines.
-Before interchanging as compressors only you must determine spline count and you can only find that out by seperating assembly.
- 8mm bolts mtg. bolts.
Hang On A/C:
AEROSTAR 90-93 hang-on AC, 6-245 (4.0L)
AEROSTAR 94-95 hang-on AC
EXPLORER 91-93 hang-on AC
RANGER 90-93 hang-on AC, 6-245 (4.0L)
Notes:
- none
i have a stock 93 compressor if u are interested just pm me.
Thanks man. That's good info. I was hoping there would be a later model could use. I guess i will buy Hoss_hanna's Until I can afford a new one.
Hoss, you have a PM
Have you tried fleaBay ?...I bought a new compressor from BlendAir on ebay for $122 shipped last year.
There are several companies that make new compressors in & around Irving, TX. The new compressors are way cheaper than the "rebuilt" ones from AutoZone & O'Reillys.
J...always bargain shopping.
just got a reman for a 92 on ebay for $100 w/ shipping. Looked like a new clutch, clean and works perfectly. Kinda had to sort out ebay, plenty of used there kinda masquerading as reman or new....
glad u got it figured out enjoy the cool breeze!
By-passing A/C compressor on 1994 Explorer
You can by-pass a seized A/C compressor on the 1994 Ford Explorer XLT with an 82" serpentine drive belt or Bando#6PK2070.
