Bmxboy
- May 9, 2001
- Chicagoland
- 2003 Corvette Z06
Ok...i am purchasing a new 200 amp alt. and was debating on upping the power wire coming off of it (i think its 4 guage, not sure)...however, when i try to follow it through my engine compartment, i get lost and have NO CLUE where it goes....does it go straight to teh battery, or does it power other things on the way there? Any help would be appreciated.
Also, when i have my subs on high, sometimes my entire vehical will cut out, my onboard computer will re-start, my subs will shut down and start up again. This only happens when i am driving...when i am in park, it has yet to do it. However, my alt (still stock) is so hot that literally you burn yourself touching it for a second. Is it just that my alternator isin't putting out enough power? It has only started to do this since it has gotten hotter out around here (never did it when it was like 40 or 50 degrees...its like 80 now)
Also, would i NEED to run a bigger power wire from the alt? Or could i slide by with the stock (2000 watts)
Thanks so much guys
Carleton
Thanks so much guys
Carleton
